5.3 going in Jeep
Old Apr 29, 2005 | 10:19 AM
jess williams's Avatar
Default 5.3 going in Jeep
Man, Im glad I found this site. I just purchased a 5.3 out of a truck and it has the drive by wire Tbody. I will have to buy a harness and computer because I just got the complete engine and accesories. My question is do I just find a pedal assembly out of a wrecked truck or do I need one from a vette? Also, does anyone have a scematic of sensor layout on the 2000 5.3 truck engines? Thanks for your time...
Jess
Old Apr 29, 2005 | 12:09 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
You can use the ETC pedal from either a Vette or a truck. There is one minor wiring change between the two.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Apr 29, 2005 | 04:28 PM
I will give you a call monday to talk about a harness and programming for my application. Thanks for your time.
Jess
Old Apr 30, 2005 | 10:00 AM
My uncle owns Diesel Depot and my dad said he has some pedal assemblies out of the diesel trucks. He said it is a 5 wire harness, would this be the same controller as the vette and gas trucks?
Old May 1, 2005 | 12:07 AM
treehugger's Avatar
im doing a dj5 conversion to a 4.3 liter 6, but im told they are VERY buildable because its just the 350 block with 2 cyl hacked off the end so most of the parts are interchangable, if its not a big problem ill go with a cast iron truck lt/s1 that my friend got cheap, ill have to see
