Supercharged 2nd gen
Old May 2, 2005 | 09:02 PM
81LS1Camaro's Avatar
Default Supercharged 2nd gen
I finally have most of the loose ends done on my car and was thinking about ideas for this winter. Has any one put a procharger on their 2nd gen LS1 camaro/firebird? I was wondering how hard it is to mount the intercooler, and where to put it. If any one has done this what problems have you run into? One other thing I was wondering, how long untill my stock A4 takes a dump with the added power? I know that this might be a good post for a diff forum but thought I would throw this out there and see what you all had to say.
Old Nov 8, 2005 | 01:34 AM
I thought I would throw this one out there again since I am driving my car and seem to want more power. Any one have any info?
Old Nov 8, 2005 | 07:41 AM
Schitzo's Avatar
I have not done this and don't know anyone who has done it but this is what I think. The procharger should not be a problem mounting onto the LS1 in a 2nd gen. There is plenty of space on the right side just above the steering box. As for the intercooler I would put it somewhere between the grill and rad support. I am looking at my 71 and there is plenty of room just below the hood locking mechanism. You might have to punch some holes on the rad support. I am thinking if the procharger kits can fit in the 4th gen which barely has any space left under the hood then it should not be a problem to fit one in a 2nd gen. You have to the first one to do this and deal with the problems I am yet to get my ls1 in but I was thinking of magna charger down the line. This might need a cowl though..... Check this link out. I know it is not an LS1 but it should give you the general idea of what to do.
http://www.procharger.com/coors_jesse_james.shtml
From that setup atleast you know the procharger will fit. You just need to figore out how to route your intake tubes without affecting hood clearance
Hope this helps.
P.S. Do you have any pics of your camaro that you can send me ? I am just starting my swap and could use all the help I can get. What headers are you using? My email is bobkiny@yahoo.com
