LS1 weight vs Standard SB 350?
it isnt a 100#.
buddy and me weighed the blocks.
the ls1 aluminum block is 48# lighter than a 2 bolt 350.
i dont know where the 100# rule came from, i thought this was true as well.
im sure the crank and cam in an ls1 weigh in more than a small block.
i just dont see how it can be that much lighter.
Originally Posted by TJ
it isnt a 100#.
Not sure if the question is the complete motor, tall block or? If you look at the complete motor, the LS1 comes in at somewhere between 390 - 425lbs....that includes everything from complete electronics to headers. Compare that to an SBC with everything from carb to headers, and I think the 100lb difference (or more, I suspect) will reveal itself. Iron head SBC I believe to be 530lbs (not complete).
BTW, can someone verify the LS1 weight (complete). I think Sallee advertises 390lbs for their crate motor, others' claim up to 425lbs.
Andy1
Andy1
....all I know for sure is that my LS-1 weighs about 20 pounds more than the 21 stud flathead Ford engine that it replaced.......and roughly three times more power.
Originally Posted by Stu Cool
Just about everything is lighter on the LS1, even the camshaft is hollow vs solid for the SBC. 100 pounds is a good ballpark figure.
Pat
Pat
i should have weighed it, but i was in a rush to put it in.
I have a stock cam that I can weigh when I get home tomarrow, if someone wants to weigh a sbc cam. Although im sure half the people on this site have a stock ls1 cam they can weigh...
