LSx swap question!
Old May 8, 2005 | 01:11 AM
SICMARO's Avatar
Default LSx swap question!
Ive been reading about the single feed fuel rails of camaro/firebirds and the dual rails on corvettes. From i understand the dual w/ the return is better? will the single inlet rail work? does it have a regulator built in like the dual rail? any info would help.... cars almost done just need the fuel system!!!!
Old May 8, 2005 | 06:26 AM
RXette's Avatar
the late model camaro ls1 has the return and fpr built into the in-tank fuel pump. there is a single inlet to the rail and a rail to rail cross over pipe. the rail is returnless.
there is a fuel tank vent solenoid on the driver side fuel rail which has a hose connecting back to the fuel tank. for high performance, many divide the fuel supply line prior to the rail and run a separate branch to each side of the fuel rail. if you do this you should have a high volume fuel pump and larger supply line. 400 real wheel horsepower is no problem with the stock single camaro fuel supply.
dan
Old May 9, 2005 | 12:21 AM
SICMARO's Avatar
well i have the stock single inlet fuel rail and a walbro inline pump. what im wondering is do i need a pressure regulator or not? if so which one should i run?
Old May 9, 2005 | 03:34 PM
red90cobra's Avatar
you could just try it and check fuel pressure. There isn't really a regulator on the 98 and up fbodys. But there is a way for the fuel to return to the tank by the t that's in the feed line after/ or before the filter. I would run a fuel pressure reg and a return or else I believe you'll burn the pump up from backpressure build up.
Old May 9, 2005 | 04:09 PM
SICMARO's Avatar
so your saying to run a regulator, can i split it at the regulator and go back to the tank and one to the fuel rail? grrr im still learning fuel injection!! im used to carbs!!!
Old May 9, 2005 | 11:05 PM
red90cobra's Avatar
Yes you can do that. feed line into the regulator and splits one to the rails and one back to the tank. That way you're pump will live longer. Hope this helps and also you have to get a hi pressure regulator.
Old May 9, 2005 | 11:08 PM
SICMARO's Avatar
ok that sounds good... yeah i know i need the hi pressure reg. do you have any suggestions on one? will that set up supply the motor correctly?
Old May 10, 2005 | 12:37 AM
red90cobra's Avatar
can you give me brief run down of how you've run your lines and size etc. let me know. the setup i've decribed should work. as for regulator aeromotive is good, get one cheap ones out jegs or summit for there brand should work for you.
Old May 10, 2005 | 02:00 AM
SICMARO's Avatar
well the car had a big block in it so we are going to try and run the 8an lines that are still in it. we are thinking that may be to big to run. not sure? We are going to run an external walbro 255lph to the single camaro fuel rail. so i think we just need a regulater and t it off there one to the motor and one to the tank as a return line. ??
Old May 10, 2005 | 06:32 AM
RXette's Avatar
i use a holley FPR that has three ports and a pressure gauge fitting. one port is inlet, another is outlet and the third is the return. this FPR holds the fuel rail supply pressure absolutely dead on. it doesn't vary 1/2 pound over the full range. it is pricey $300, but really does the job. it has a reference vent that you can either hook up to manifold or atmospheric pressure. the fuel rail also has a gauge fitting so you can see if your supply line is restricting flow by comparing the reading on the rail with the reading on the FPR at wot..
dan
Old May 10, 2005 | 12:28 PM
red90cobra's Avatar
the 8 an line will work great. give you lots of room to grow. Hope this help you. Look up some regulator and find the one your want and come back and post a link.
Old May 10, 2005 | 04:43 PM
SICMARO's Avatar
aare there differnet fpr for carb engines and fuel injec ?
Old May 11, 2005 | 12:12 AM
red90cobra's Avatar
yes one is designed for low pressure and the other hi. usually the efi's are good to some 70 other to 100 psi.
Old May 11, 2005 | 12:39 AM
SICMARO's Avatar
ok thanks for your help!
Old May 11, 2005 | 01:32 AM
red90cobra's Avatar
anytime
Old May 11, 2005 | 08:22 AM
RXette's Avatar
my holley has a very wide pressure control range. i can regulate the pressure from 20 to 80 psi. btw, the lower the supply pressure, the larger the supply lline will have to be to get the same fuel volume flow. it is pricey. $300
dan
