runs 5 seconds and dies
my 2002 camaro ss LS1 engine is in a 1993 rx7. full california smog legal setup. all stock.
after hooking everything up, the engine fired up immediately and then quit. it does this over and over. the computer shuts the injectors off. i do not have the exhaust done so the cats and oxy sensors are not installed. the oxy sensors are plugged into the harness.
i also have installed a vats bypass. all of the rx7 chassis functions operate, instruments etc.
i have found a tuner that can make the computer happy and ignore any codes for $350 but i would rather solve the real problem as well as save the bucks. any and all suggestions are appreciated,
thanks, dan
also, i assume that the pcm looks for some signal from the bcm, which i do not have.
do you know if there is any way to verify the function of the vats. the red light is on so it is getting power. does the signal lead put out a particular voltage? i will measure the output both ac and dc and also switch the pcm pin connection and post the result.
thanks for your response.
dan
i dont think baker has a box for that.
your advice is welcome.
thanks, dan
thanks, dan
LS1edit isnt worth the $$ IMO.
HPtuners however, is perfect for the novice swapper that wants to learn.
with HPtuners, you would get the scanner along with the tuner... and the scanner is worth its weight in gold.. (or more so, since software doesnt weigh much
)how easy is it to change VATS you ask?
so simple that i did a full walk thru in about 5 seconds. lol
load the editor, open your PCM file, and click Edit->system>general
and you end up here...
click it off, hit save and send it off to your PCM
the DTCs and 100 other small things you may need to edit are also pretty easy.
and with some minimal learning, you can do simple tuning..... like for a cam and such..... is your tune going to be better then the pros? no, not until you learn some tricks..... but can you get it 95% there yourself? yea, if you're willing/able to invest the time.
if i was in your shoes right now, id buy HPtuners all over again. the scanner keeps me from banging my head on the wall.
if you dont want to do that right now, id atleast get someone with a laptop scan tool to watch whats going on.
i have dual fans now, but for the first month, i just had a single fan... but i mixed up #2 and #1... and since i only had one, it was #2.... so i did that for a month... now i have both fans, and its normal again.. lol
dan
If your PCM came from a truck or Corvette, THEN the VATS thing is useless.
If you have a scan tool and can read the VIN from the PCM, that will tell you real quick what you have.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
and also, thank you john. i do have the vehicle vin which says it is a camaro ss. but, now that you mentioned reading the vin from the pcm, it occurred to me that the salvage yard where i bought thels1/t56 could easily have sent me a pcm from anything laying around.
the world is full of hazards for the naive or unwary, isn't it?
dan
live & learn.
if this is the problem, i will beat my head against the wall. haste makes waste.
thanks, dan
Heck it cost me $1,500 AUD to get mine done, I'm not complaining and I dont make a lot of $$ either.
live & learn.
thanks, dan
umm, the PCM "forgets" alot of the error codes when its disconnected from power.
do you mean he'll disable some DTCs?
live & learn.
thanks, dan
www.speartech.com
man i am learning a lot from this thread. i thought the tough things would be the mechanical things. the install of the ls1/t56, taller diff, driveshaft, torque arm, clutch master cylinder etc would be the main challenge. those things just took muscle. this electrical stuff takes brains. not my strongest asset.
dan
if my friend deletes some relevent dtcs and the vats, so much the better. if that does not help, i now have several good suggestions.
i had previously tried it without the oxy sensors plugged in and gone over the connections.
i have been active on v8rx7.com since i started the project. i owe my progress to that forum. i have gotton as far in 3 months as the early guys took a year or more because they are so willing to help a noobie and tolerate all my stupid questions. my screen name there is danzan149. i think this is a great forum and i have learned a lot in this very short time. i hope i can contribute something back.
thanks for your comment,
dan
I learned a great deal if not all of the knowledge about my swap from this site. I really owe it to all the guys here for my swap getting completed, with that said I try to help other people out as much as I can and return the favor that way.
Also, just to throw this out there, my car ran for the first time with no MAF, O2 & IAT sensors and open headers so..... I bet it has something to with VATS, especially if the injectors are shuting off.
