Disc brake kits....
Old May 25, 2005 | 12:51 PM
autokraft's Avatar
Default Disc brake kits....
I`m looking for a complete aftermarket disc brake setup that has everything you need including master cylinder for a 69 camaro. What is everyone using and what brands sell complete kits? Any pro`s or con`s?
I`m running 17in wheels.
Thanks, Kurt
Old May 25, 2005 | 04:10 PM
Oscar Will's Avatar
I got my complete setup from ECI, everything was matched and the car stops like you hit a brick wall.
http://www.ecihotrodbrakes.com/
Old May 27, 2005 | 05:02 PM
KacyZ28's Avatar
if you currently have front drums you can do a conversion to 98-02 brakes all the way around and they all just bolt on
Old May 27, 2005 | 09:30 PM
76LS1BIRD's Avatar
Restricted User
I put LS1 brakes on a 68 camaro. they require some machine work
The hubs get turned down so they fit the LS1 rotors,& you need
longer wheel studs. the spindle needs machining so the cal. bracket
sits flat. Spindle is very hard so you need carbide tooling.
I have a spare set of laser cut brackets.( For front only)
good luck Dale
Old May 28, 2005 | 04:43 AM
69MyWay's Avatar
You will love these:
http://www.touring-classics.com/
Old May 28, 2005 | 08:18 AM
76LS1BIRD's Avatar
Restricted User
There is good info. on pro-touring.com
dale
Old May 30, 2005 | 05:38 PM
KacyZ28's Avatar
good luck Dale
i used a washer to space the bracket out
Old May 30, 2005 | 10:02 PM
T23LS1's Avatar
I bought a kit complete booster, hoses, calipers, pads, master cycl, dsic, bearing, and w/ drop spinddles- $750. From McGauphy's. It would be even cheaper without the spindles(about 500). Very good kit. Also if you want a Baer kit OPG has em for under $1000 without booster.
