LS1/Powerglide.
Old May 25, 2005 | 04:19 PM
69cam's Avatar
Default LS1/Powerglide.
Anyone know the part number for the spacer I need to bolt my powerglide and NON LS1 converter to my ls1? Thanks
Old May 25, 2005 | 06:05 PM
Keith's Avatar
https://ls1tech.com/forums/showthrea...er+part+number
Post #20 should have the info.
I believe it is the correct spacer.
Old May 25, 2005 | 08:18 PM
69cam's Avatar
Thanks.
Old May 29, 2005 | 08:00 PM
LS1exus's Avatar
Just out of curiosity, is there any particular reason you want to adapt a 'glide to a LS1? I'm not knocking it or anything, I'm just wondering.
Old May 30, 2005 | 12:48 AM
01PewterWS6's Avatar
Drag racing
There is a fast LS1 Fairmont wagon around the DFW area running a PG
Old May 30, 2005 | 10:51 AM
Stu Cool's Avatar
In a light car a powerglide works great for drag racing. I had one in a '63 Nova with 400 SBC and it worked great. With the right torque converter and a broad torque band they will work better than a T350 or 400. Very little power loss through the tranny and light weight too.
Pat
Old May 30, 2005 | 06:49 PM
LS1exus's Avatar
I guess that's a pretty good reason, lol. I was just wondering.
Old May 30, 2005 | 09:26 PM
TJ's Avatar
TJ
greater use of the power on hand. pulls across the torque band much longer than any other automatic. less shifts= better ET. this does depend on the weight and gearing, but its very possible.
Old Jun 7, 2005 | 07:59 PM
bmcdaniel's Avatar
check with TCI, I installed a 99 LS1 in a front engine dragster and used a powerglide. Works grat and get some good time slips.
Old Jun 7, 2005 | 09:44 PM
TJ's Avatar
TJ
any timeslips?
how much does the dragster weigh?
sounds like an awesome bracket combo.
