ecm is junk.
Old Jun 2, 2005 | 10:35 PM
LS1rscamaro's Avatar
Default ecm is junk.
well i did all the test i was told to do but it leads me right to the ecm and i was told that the car ran right before the motor was pulled along with the ecm, but im guessing in the striping of the car some how the ecm got shorted. how much do these things run? and is there any way to test them or take them to some where to be tested??
Old Jun 2, 2005 | 11:48 PM
LS1Sandrail's Avatar
The chances that it is a PCM versus an error in the wiring is very low, in my experience.
If you've not done so already, take the PCM out of the circuit, and using a resistance meter check all your grounds against the pinout for your year of PCM and harness. Check all the pins and make sure something isn't being grounded that shouldn't.
Put the meter on volts or use a test light and probe the connectors to the PCM for voltage. Only the keep alive voltage should be found. Turn the ignition on and make sure there is voltage everywhere there is supposed to be with the key on. I usually pinout check the connectors to the fuel injectors and the ignition too to make sure those are wired correctly for 12V and grounds.
After having done all that and you still think that the PCM is bad, you can buy one from a junkyard. Car-parts.com has them for $30 and up. Wait4meperformance has them for $120 checked out and ready to go. I imangine Nelson, Speartech, wait4me could check one out for you. Dealer might too. The easiest way to check is to take the PCM and put it in another car and see if it works. If it still doesn't work but doesn't blow the fuse, maybe you could get some codes off of it and confirm the box is bad.
Just my 2 cents. I may be telling you things you've already tried.
Phil
Old Jun 4, 2005 | 12:44 AM
no actualy its very use full and ill try it im just so bumed because im so close to starting this thing and now a nothere problem. im almost bank rupt form this dam car. but i was going to try it in my buddys ws6 to see if it still blows fuses. thanks again for the info.
