V6 to LS1
Old Jun 12, 2005 | 11:01 AM
Jack Roberts's Avatar
Default V6 to LS1
I have a 96 Camaro convertible V6 that I am converting to LS1 power. I am an auto tech with over 20 years wrenching,and have swapped LS1 motors(kid ran 99 T/A out of oil!) in and out of a 99 T/A. Is there a conversion "kit" for this made by anyone or is it a piece by piece job? Motor mounts,engine wiring harness,computer,fuel pump,and all the other "little" things? Is there a specific thread or place I should look to find/reference these things? Any help/information greatly appreciated!
Old Jun 12, 2005 | 12:02 PM
Klortho's Avatar
Best thing to do is get a complete k-member and engine with wiring and underhood portion of the wiring harness. The LS1 k-members will bolt up to the '96 model. The dash harness is a little different as well, might be worth an entire 99+ harness swap.
Old Jun 13, 2005 | 07:52 AM
Well if I get a K member from say a '99 w/motor and harness will the electrical harness plug right in? What about fuel pump pressure,computer that's already in the car?
Old Jun 13, 2005 | 08:00 AM
Klortho's Avatar
You would be basically taking everything from the V8 car, k-member, wiring, computer, and swapping it into the V6 car. The fuel pump is different as well.
Old Jun 13, 2005 | 04:19 PM
peteZ's Avatar
Check this site to check out: http://www.dxsoftware.com/magnus
Old Jun 13, 2005 | 04:23 PM
Camaro_Zach's Avatar
i too have done this, i actually was with magnus for all of his swap and then did my own entirely solo. so hit me up if you actually get everything and need some help.
Old Jun 14, 2005 | 06:58 AM
Thanks for the info guys! Zach you are a wild man ! Remind me of myself.....guy installs ls1 at home in the garage....shade tree style....lol....j/k .Thanks fer the pics,awesome job for at home!Very innovative and ultimately slick. I recently(last week) built a Pontiac 400 in my dirt floored garage using my engine lift and some wood blocks !Running awesome ! Anyways great job,I noticed you're smiling in most of the pics(can't imagine why !).Good documentation of the process,great pix.Thanks!!!
