Late model RX-7 Conversion people come in here.....
-sorry about the length of the post.
-John
-John
Good luck though you probably wont have as much fun as we are with the install but you will once you get on the road.
http://members.tripod.com/~grannys/2...ructions1.html
Dont think you can blame any kit company on having to fabricate a little.. The 2gen looks a little simpler...
The Granny's kit I would avoid for an LS1 3rd gen FD. Their kit for a second gen FC uses the standard motor mounts from their older V8 Chevy kits with an adapter plate bolted to it. The motor mount kits are universal for the GM engines (LT1/L98 and older) FYI. The kits that Granny's makes for 2nd gen RX-7's seem to be good (Ford or Chevy). The 3rd gen Granny's kit I wouldn't even contemplate using as LS6FD has painfully found out.
Good luck with your project Phoenix. Saving 400-600lbs+ and having a car that can handle/brake with looks as stunning as the FD should make up your mind.
