TB Coolant line to an LT-1 radiator
I am using an LT-1 corvette radiator to cool my LS1, but there is no provision for hooking up my throttle body coolant line. Where can I hook up the line for proper coolant flow through the system? Should it be connected on the driver side of the radiator (in the pipe from the water pump through the power steering cooler) or the passenger side (side with water neck)? Could I just run it into the lines I am using for my heater core (the two outlets on the water pump housing)?
~Bob
~Bob
over & over again, but, it seems that the "best" or "ideal" connection seems to be at the highest point in the radiator/cooling system. This is what I have gathered from most other posts. If there is no provision/connection, you must invent one. Reason being, the highest point in the system is where the air in the overall cooling system, naturally rises to...both statically & while in use. Hope this helps. Gar
Over on the JTR website there is a LS1 datsun conversion page. A little ways down they have a Tee for this purpose. 1 5/16 X 5/16 Tee. Here's a link.
https://shell7.tdl.com/~jags/Datsun-Z-LS1-V8_Order.html
Thanks for the help,
Bob
