2000 LS-1 in '98 Camaro !??
Old Jun 16, 2005 | 12:17 PM
Bent's Avatar
Default 2000 LS-1 in '98 Camaro !??
Hi
I have a 1998 Camaro automatic with a dead LS-1 ! Is it possible to put a 2000 LS-1 engine in the car, from a Camaro with manual transm. and use the '98 wiring and computer ??
I live in Denmark, and LS-1's are hard to find, so I could buy this eng. from a crashed Camaro, resting in Sweden !!
Thank you in advance
Bent, Denmark
Old Jun 16, 2005 | 12:39 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Sure. Just transfer your flexplate, oil pressure sending unit, and coolant temp sensor over to the 2000 engine, hook it all up to your 98 harness and you should be good to go! Be sure you get the coil packs with the newer engine, as they mount differently than your 98 engine, but it all plugs in the same.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jun 16, 2005 | 01:12 PM
Brains's Avatar
Heck, we put the heads from a 99, on a 2001 truck block, into my g/f's 1998 Camaro. My Formula has 1998 heads on a 2000 truck block. Everything in the "Gen-III/IV family" bolts up identically.
Old Jun 16, 2005 | 01:46 PM
LS1 Hybrid Magna's Avatar
Bent sent you a pm.......if you need LS1 parts/ or a GM shop manual.......
Old Jun 17, 2005 | 06:14 AM
Bent's Avatar
Thank you very much guys - I will check to see if I can get the engine, and then get started !!!
Thanks again.
Bent, Denmark
Old Jun 17, 2005 | 07:43 AM
Frizzle Fry's Avatar
I thought the engine harnesses were tranny specific? You can mod the tranny connections though.
Old Jun 20, 2005 | 11:29 PM
01WS6/tamu's Avatar
Nope thats why all of us here drive the generals best. Only ford pulls that crap. Only choice is either auto or stick and you can add or delete trans functions with very little hassle.
