Mustang Ls1 headers
Old Jun 28, 2005 | 11:13 AM
CMcCarthy's Avatar
Pro Stock driver and fabricator extraordinaire Gene Wilson has a twin turbocharged dohc 4.6 in a 4 door focus. Talk about your sleepers... that thing takes the cake.
Old Jun 28, 2005 | 06:46 PM
Bimmer Tech's Avatar
Sweeeet......That thing has to be a rocket!
As far as headers go for the swap, looks like with the limited space, the mid length that come with the kit would be ideal....On with the project!
Old Jul 3, 2005 | 02:57 PM
red90cobra's Avatar
I tried a set of longtubes not sure what kind but it would not clear the damn steering knuckle. Anyone around dfw have a set of longtubes for a fox I could use to test fit. I will leave a deposit on them so i can see what fits. Here's the steering knuckle.
https://ls1tech.com/forums/attachmen...chmentid=36150
Old Jul 4, 2005 | 01:32 PM
VTESPEED's Avatar
Make sure the kind you try is a set of 351W fox body and not 302 headers...they fit quite a bit different
Old Nov 28, 2005 | 06:38 AM
1dirtyZ's Avatar
any pics?
Old Nov 28, 2005 | 08:43 AM
93Polo's Avatar
Gene has been known to cruise around in some real sleepers.
Old Dec 5, 2005 | 05:19 AM
1dirtyZ's Avatar
any part numbers for those headers?
Old Dec 5, 2005 | 05:29 AM
1dirtyZ's Avatar
from what i saw these headers are for standard trannies only? would that be an issue with a th-400??
Old Dec 5, 2005 | 08:18 AM
Brains's Avatar
I test fit a pair of Pacesetter LS1 longtubes in my car, and they almost fit perfectly. The only thing I would have needed to do to make them fit in as-is would be to lower the engine about another 3/4" or so.
Old Dec 5, 2005 | 01:47 PM
89lx-ls1's Avatar
I used the 351 mac 13/4 longtubes and min. mods were needed and it cleared my steering perfect.
Old Dec 5, 2005 | 03:56 PM
ls1stang's Avatar
What kind of mods did you have to do? I am actually trying to fit my headers now, and am not having much luck, I'm using mac 1 3/4 long tubes in a 95 with a 4.6 tubular k-member. any help would be great.
Old Dec 5, 2005 | 04:23 PM
  #32
89lx-ls1's Avatar
tHE DRIVERS SIDE I HAD NO PROBLEM JUST SLIGHT ADJMENTS BEFORE I COULD WELD BUT THE PASSENGER SIDE I HAD TO TRIM THE K MEMBER AT THE BOTTOM WHERE THE 2 BOLTS ARE I HAD TO CUT IT TO WHERE THERE WAS ONLY 1 BOLT AND I HAD TO MOVE THE THIRD PIPE ON THE HEADER I CUT 1/2 INCH OUT OF IT WHERE THE PIPE COMES DOWN AND THEN IT TURNS BACK THAT IS WHERE I CUT OUT THE 1/2 INCH RIGHT AFTER THAT BEND. AND I HAD TO SLIGHTLY FLATTEN THE TUBE THAT IS RIGHT NEXT TO THE FRAME RAIL
Old Dec 5, 2005 | 04:59 PM
  #33
ls1stang's Avatar
what kind of motor mounts are you using?
Old Dec 6, 2005 | 05:10 AM
  #34
1dirtyZ's Avatar
from what i'm reading i think using a set of pace setters and maybe tilting the engine back a bit would be the easiest way?
to the guys that used pace setters , do you think they would fit if the motor was tilted back a bit ( if so how much tilt is needed?)
will the oil pan clear the k-member ( or will there other issues) if the motor is lowered about an inch?
Old Dec 6, 2005 | 07:11 AM
  #35
Brains's Avatar
With my AJE tubular K, I could easily lower the engine enough to clear without issue
Old Dec 6, 2005 | 08:00 AM
  #36
1dirtyZ's Avatar
I didn't know the motor mounts on the AJE where adjustable?
so just to clarify, if i use pace setter headers, 4.6 engine mounts, and a AJE k member i won't have any issues?
Old Dec 6, 2005 | 09:36 AM
  #37
Brains's Avatar
They're not adjustable, but there's nothing stopping me from cutting and welding the mount perches
I'm going to open up some dialog with a couple header manufacturers (starting with LS1Tech sponsors of course), and see if this is something they'd like to persue offering.
Old Dec 6, 2005 | 11:26 AM
  #38
89lx-ls1's Avatar
I Used 4.6 Motor Mounts And A Profab Tube K Member And A Th 350 Trans And My Headers Are Pretty Low But They Are About 1/2 Inch Off Of The Trans On Both Sides.
Old Dec 7, 2005 | 10:37 AM
  #39
Lane's Avatar
I had a QA1 K member from a 4.6 car, which I had to trim some of - using Mac 1 3/4 LT's. Had to also re-route one primary on each side. Took some work, but they turned out real nice.
Old Dec 9, 2005 | 11:55 PM
  #40
1dirtyZ's Avatar
here's another question for ya! AJE offeres a dropped steering rack option ( i think it was 1.5) , will this help any with the steering shaft hitting the header issue?
