So many pink wires
it seems pretty simple. Mostly already wired up and stand alone.
I understand
orange is always hot
pink hot in start and run
purple hot in crank for starter.
But there are about 20 pink wires.
Do I fuse them seperately.... power them with a relay.... tie them in 3 or 4 large bundles and then fuse them???
Also, on my pinout, number 9 on red bundle is the "fuel pump" dark green/ white. Is assume this is going to my fuel pump relay, but does it supply the 12v or the ground to close the relay (so I know what to put on the other side of relay).
Any help is appreciated.
I understand
Bank 1 Coil power and injector power
Bank 2 Coil power and injector power
MAF and O2 power
Transmission power
ect...
they all should be fused separately with a appropriate sized fuse
umm, yea. i totally agree 100%
and since each pink wire is seperate for that reason, you end up with several groups of one... lol
no two of thoes wires should goto the same fuse.
