97/98 Vette FPR Reference?
http://harlan-engineering.com/incon/..._enginebay.jpg
The tube you see is the "fuel pressure regulator purge tube" and has nothing to do with pressure regulation.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
Wow! Thanks alot John! GLad to hear its just that easy!
Keep in mind, you still need a regulator and return line somewhere in the system in order to maintain the needed 58 psi. The changes to the injector table are based on the size of the injectors and whether the regulator is vacuum referenced or not.
www.speartech.com
It won't be much longer.
www.speartech.com
