Ls2 Pully Question
Old Jun 24, 2005 | 09:41 AM
bhernquist's Avatar
Default Ls2 Pully Question
I just purcahsed an LS2 crate motor and am having difficulties locating the proper accessories and brackets. Specifically, do F-body, LS1 accessories fit? Must I use 2005 Corvette brackets?
Old Jun 24, 2005 | 10:17 AM
Oscar Will's Avatar
I'm using all f-body stuff on my LS-1 except for an LS-2 water pump. Since it (the pump) fits tighter to the front of the engine....belt alignment is a problem. You either need to use all LS-2 accessories or do like I did....use all LS-1 F-body parts and then use a puller to pull the water pump pulley forward about 1/4" so the belt lines up. I used the LS-2 pump because of my clearance problem between the motor and the radiator. I have 3200 miles on it now and it's been flawless.
Old Jun 24, 2005 | 02:48 PM
bhernquist's Avatar
Thank you for the help!!
