4L80e cooler plug and oil level
While I have your attention, Shy of the Lokar rip me off set-up. What can I do for a tranny oil level dip stick and tube? Am I able to run a factory set-up and bend it so it clears my firewall or will that alter the readings?
Thanks guys!
-Matt
1"=1" etc...
Thats why I suggested using the stock lines, instead of trying to change the fittings etc.
Remington
the adapters are available at the local hose shop that makes braided lines, if you have one in your area, id check there.
good luck.
