Another speed sensor issue?
Old Jun 28, 2005 | 04:38 PM
GTS346's Avatar
Default Another speed sensor issue?
All you conversion folks running non standard transmissions what are you using for speed sensors?
I found a few sensors but they are hall effect style ( three wire) when the LS1 uses a Magnetic reluctor style (two wire).
Has anyone used a 3 wire hall effect sensor and had good results?
Old Jun 29, 2005 | 07:02 AM
Uk Robert's Avatar
I asked this exact same question and was told to use the reluctor wheel and pick-up from a company called Jags That Run (JTR). This goes between the propshaft flange and pinion flange. I`m using a Tremec TKO11 in a Ford(Mercury) Capri behind the LS1.
Old Jun 29, 2005 | 04:32 PM
GTS346's Avatar
Do you have a link to some pics or more info?
What does it cost etc?
Old Jun 30, 2005 | 07:20 AM
Uk Robert's Avatar
Yes, go to www.jagsthatrun.com - scroll down the page and look for "reluctor wheel". About $75/100 I think
Old Jun 30, 2005 | 04:15 PM
GTS346's Avatar
Will it work on a TH350?
Just had a look pretty sure thats just if you want to run a speedo cable off a 4L60E?
I need to get a VSS signal for a PCM
Old Jun 30, 2005 | 04:50 PM
01WS6/tamu's Avatar
Are you running a long tail or short tail 350? If it is a short tail you can take out the gear and install the metal reluctor for a 700r4 onto the output shaft of the 350. Get the reluctor and vss sensor from an 88-92 chevy fullsize pickup with an automatic, then hook the vss wires up as you normally would.
Old Jul 1, 2005 | 02:20 AM
GTS346's Avatar
Can I still use my factory speedo cable then?
I am running a short tail.
Do you know the cost or any part numbers?
