clutch anticipate switch
Old Jul 3, 2005 | 04:00 PM
valetudo's Avatar
Default clutch anticipate switch
Is the clutch anticipate switch necessary for the car to start on a 2002 LS1? If so, should the line for the anticipate switch just connect to ground when the clutch is depressed?
Old Jul 3, 2005 | 04:23 PM
84z28ls1's Avatar
no, the clutch anticipate switch is just what it says. It lets the PCM know when your about to shift so it can flare the engine up a little between shifts. It also tells the PCM to shut off cruise control when you touch the clutch pedal. And yes pin D blk/wht wire goes to ground and the other pin C gry wire goes to the PCM connector C1 pin 32. At least on a 99 f body but it should be the same from 99 on up.
Old Jul 3, 2005 | 07:03 PM
valetudo's Avatar
does that mean that the clutch anticipate switch connects to ground when the clutch is being depressed? Thats what I wanted to know.
Old Jul 3, 2005 | 07:04 PM
SUPRYZE's Avatar
You don't need it to run. I'm currently not running one myself because I have no way to mount the one I bought to the pedals I'm using.
Old Jul 3, 2005 | 07:47 PM
MrDude_1's Avatar
on a hybrid conversion, you can safely disable the SES code for the clutch switch without a problem...
to start the motor, the purple wire leading to the starter 'noid needs power... most cars have a large clutch switch at the BOTTOM of the pedal (pressed when fully depressed) and a anti-theft relay... that part changes from car to car... but bottom line is, you put +12v to that purple wire on the harness, and it'll turn the motor over.
if you're not getting power to it when you turn the key, start checking your car connections.
Old Jul 3, 2005 | 08:02 PM
SUPRYZE's Avatar
Are we talking about the Clutch Anticipate switch or the Clutch Start switch??? The start switch I am running for saftey reasons.
Old Jul 3, 2005 | 08:57 PM
MrDude_1's Avatar
both.
i was trying to answer the orignal posters question.... the clutch anticipation switch, is the switch im talking about disconnecting.
you REALLY REALLY REALLY should use a clutch start switch....
Old Jul 6, 2005 | 07:29 PM
valetudo's Avatar
On my RX-7, I have two separate switches. One is triggered when clutch is depressed, one is triggered immediately the moment the clutch is hit (the anticipate switch). My question is whether or not the signal going to the PCM should pull down to ground when the clutch anticipate switch is triggered or whether it should pull up to 12 volts. Does anyone know this?
