Cable-X calibration question: T56 "gear" teeth?
The formula to set the dip switches is as follows:
Transmission gear (#of teeth) X axle ratio X tire revs/mile = pulses per mile
The pulse per mile is compared to a chart and the switches are set accordingly...
My question is: Since the T56 has a VSS instead of a standard speedo gear, what number do I use for # of gear teeth? From my research I learned that the T56 has a 40 tooth reluctor wheel (40 pulses per driveshaft rotation). Would that be the number I use?
40X3.45X734 = 101,292
Would this be right? What have others used to calibrate their Cable-X?
Thanks.
That's the easiest way to set it up.
BTW, the T56 has 17 teeth on the reluctor, not 40.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
What's the range of their settings??
www.speartech.com
Then I can use the 4000 ppm in the chart for the switches. They also say that I'm risking a bad signal by going with the PCM feed rather than directly from the VSS but suggested I could try it first and if I get a jumpy needle, to run a new wire.
