cooling question, need help!
Old Aug 1, 2005 | 06:07 PM
1971ssLS1's Avatar
Default cooling question, need help!
i have a ls1 conversion in my car, with a 160 t-stat, aluiminum radiator, and dual electric fans. There is one sensor that is located on the front drivers side cyl head that reads the water temp for the ecu. i put a sending unit for an autometer water temp guage on the rear on the passenger side head. While idling, the guage for the ecu reads a consistant 195-196 while i had a scanner pluged in. at the same time, the guage kept rising and rising to like 220-230. as is starg to drive though, the guage eventually drops back downb to about 165. just trying to see if there is an explaination for this? thanks for any help!
Old Aug 1, 2005 | 10:18 PM
1971ssLS1's Avatar
nobody has ran across this, i know that everyone taps that plug on the right head and uses it for a water temp sender...
Old Aug 1, 2005 | 11:44 PM
digitalsolo's Avatar
Could be an issue with the connection to the sender, or a bad ground (assuming this is an electric gauge). Your ECU sender is probably right.
Old Aug 2, 2005 | 09:25 AM
redmist's Avatar
Sounds like a T-stat issue. Pull the T-stat and see how the temps compare.
Old Aug 2, 2005 | 09:47 AM
1971ssLS1's Avatar
your saying just pull it out, leave it out, then run it without it and see what happens?
Old Aug 2, 2005 | 09:58 AM
Muffracing's Avatar
It sounds like an air bubble in the cooling system. That will make the gauge bounce, but if the temp from the ecu isn't bouncing around I would check your gauge. Is it electric or mechanical?
Old Aug 2, 2005 | 10:08 AM
1971ssLS1's Avatar
it is an electric autometer guage, i have done what i could to keep the air out of the system, it seems like it just started all of the sudden though. i wonder if the sender is just pickinup any extra heat?? im not sure whats happening, all i know is the sensor for the ecu doesnt read the same.
Old Aug 2, 2005 | 03:10 PM
redmist's Avatar
Yep just pull the baby out, hook everything back up and check it. If you still have temp diffs then I would make sure all the air is out of the system.
As you know senders are made for particular guages. If you hook the same guage up to different senders you will get different readings.
You might want to but/borrow one of those infrared temperature readers and hit each head and see how it compares to the guages to evaluate their accuracy.
Old Aug 8, 2005 | 02:57 PM
1971ssLS1's Avatar
ran it w/out the t-stat, decided to try my luck with a new t-stat and sender for the guage, and same thing happens, any ideas????
Old Aug 8, 2005 | 04:50 PM
NO CATZZ's Avatar
Did you run your coolant crossover tubes or did you plug them? That might cause a difference from head to head if you don't have your front and rear crossovers in place. I am not saying that is your problem but just throwing it out as a possible scenario...and if they are in place maybe they are plugged with junk.
Good luck
Old Aug 8, 2005 | 05:22 PM
1971ssLS1's Avatar
good idea, thanks, i will check that out the next time i drain the system, ntil then, anything else...?
