S10 LS1s help
Old Aug 1, 2005 | 07:20 PM
XtremeDime's Avatar
Default S10 LS1s help
im gonna be dropping an ls1 in my 99 x and was wondering what parts you all used for the conversion. ive got a turbo 350 transmission lined up already and some internals for it. where did u get ur swap parts from?? thanks in advance
Old Aug 1, 2005 | 07:53 PM
Jake the SSnake's Avatar
JTR...Jags that run they have a great reputation.Ls1 performance parts doesn't seem to be doing to good check out wilds thread on his 4x4 s10 swap.I bought an instuctional cd from v8s10s I think is the name.Lots of good info but you can find most of it if you do your research.Im using a 5.3 oil pan then cutting and boxing in the front crossmember.Most people use corvette accesories and brackets. Check the stickies at the top for part #s. They give a little bit of much needed room
Old Aug 3, 2005 | 08:15 PM
S10xGN's Avatar
This may help... I bought one mainly for the electrical info.
Russ
Old Aug 3, 2005 | 10:18 PM
XtremeDime's Avatar
i ordered one like 2 months ago but theres no sign of it.
