More Swap Questions
Since the LS2 is driveby wire, a different TB/intake will be needed, correct? Will the LS6/fbody TB swap right over? Can I use the stock LS2 TPS? Will the LS2 fuel rails and injectors swap over?
Also, can I use LS1 wiring harness and computer or do I need to use the LS2 wiring harness and computer? Can I use the LS2 harness and LS1 comp since I will be switching to a mechanical TB?
Thanks again
Nick
'88SS
Thanks again
Nick
'88SS
