92 maro rs engine swap...
Pace Performance (similar to Scoggin Dickey) has the LS2 for under $6000 (no ECM or harness), LS6 for $7000 (no ECM or harness), or LS1 for $6500 (includes ECM and harness.)
If you plan on going with a manual transmission I would recommend the Tremec TKO (more shifter options than the T-56), don't know the cheepest place for this transmission.
Automatic transmission I would recommend the 4L65E or 4l80E. The 4l65E is what the Silverado SS, Escalades, H2, and Corvettes use. The 4L80E is what the silverado HD (5.3, and 6.0) has in it. The 4L65E also has a lower first gear than the 4L80E, but the 4L80E is a lot stronger, so you would have to pick your preference. Check out Pace Performance Transmission Section.
Some website to look at for starts but there are many more also:
Street & Performance (brackets, mounts, oil pans, articles on LSx conversion and they explain the difference between the LS6 and LS2.
Scoggin Dickey (engines, transmissions, and performance products.
