LS1 installed into 1982 Trans Am, need tech support
Old Aug 8, 2005 | 10:49 PM
mexricanboy26's Avatar
Default Ls1 installed into 1982 trans am need tech support
Hello everyone! my LS1 is now in and bolted up into my 1982 Trans-am. I'm awaiting for the guys at Lt1 wiring to joint my 82 cross-fire injection harness to the 99 Ls1 ones and there modifications. Thing's that I still need to do is, swap the old gas tank with the LS1 one and fuel pump. That I currently have at the shop. Only thing is I need the fuel lines to it. My thought is this.. use the Ls1 plastic fuel tank with its fuel pump and look for fuel lines of a 99-2002 trans am and put those in my 82 trans am. Will this work? if any one can give me some tech support on that it will be highly appreciated! I will list some pictures below of my project along with my K.I.T.T. car
Attached Thumbnails LS1 installed into 1982 Trans Am, need tech support-0712051229b.jpg
Old Aug 8, 2005 | 11:13 PM
SweeTbone's Avatar
Well, I can't answer your tech question, but whose nose and scanner is that? Don's? How is the interior coming along?
Old Aug 8, 2005 | 11:19 PM
Default 1982 trans am Ls1 need Tech support (pix)
Hello! Just finished installing my Ls1 into my 1982 Trans-am with ex Cross-fire injection. To complete I need to install the wiring harness witch I'm waiting to recieve from the guys at Lt1. Spoke with Dana, very helpful guy. Last will be to replace the old gas tank with the Ls1 plastic tank and fuel pump. This is were the Tech support I need comes into. If I install the Ls1 tank and pump can I just run its fuel lines into my 82 and reach all the way to the front? I don't have the fuel lines yet but still looking for them. I thought I go this route since I have the tank with its pump and avoid the aftermarket fuel regulator. Has anyone done it this way? I have not bolted the tank in yet, any trouble doing so? or just bolts right in? I will attach some pictures of my project. Here are some links to view pix..http://img241.imageshack.us/my.php?i...e0614rh3cq.jpg
http://img228.imageshack.us/my.php?i...ture0643lr.jpg
Reiko,
ps. I will try and post other pix, get error messages that say's, file to big.. grr, tried but cant figure it out.. any help on that one too
Old Aug 8, 2005 | 11:54 PM
ex-SS-ve's Avatar
just use the ls1 sending unit in your 82 tank may take a lil modification. then adjust the float to match your tanks volume. or if at all possible make your own 1/2 inch lines and sump your tank and use a bg fuel pump. and a adjustable press regulator.
Old Aug 9, 2005 | 01:04 AM
ACW's Avatar
ACW
If they're too large to attach, just upload your photos at http://www.imageshack.us/ or http://www.photobucket.com/ and link to them here
Cool project, I like those KITT/KARR cars.
Old Aug 9, 2005 | 01:51 AM
Default Thnx
Thnx guys! No they are not Don's. I purchased the scanner on ebay of this guy name ... shoot I forgot lol one with the sound effects. Good scanner it does its justice! and for the other guy thnx for the link how to shrink my pictures!
Old Aug 9, 2005 | 06:16 AM
76LS1BIRD's Avatar
Restricted User
I used stock tank with 99 pump/sender & and the 99 lines
Had to lenthen them to fit 76 bird. good luck dale
Old Aug 9, 2005 | 09:40 AM
Thnx Dale! stock tank as in the 99 tank? will u happen to have some pictures?
Old Aug 9, 2005 | 05:45 PM
76LS1BIRD's Avatar
Restricted User
Stock tank from 76 bird ,The hole on RS is for 99 pump assy.
Old Aug 10, 2005 | 01:59 AM
Thnx! now how did u get the air the ls1 air cleaner installed? mines seems to be to high, have not tried it with the hood installed to see if it hits. Did you have to play with the frame a lil bit?
Old Aug 10, 2005 | 05:55 AM
76LS1BIRD's Avatar
Restricted User
I have the 99 front frame on my car. Everything under my hood is 99.
Look at all my pics. (99 to 76 conv.)
Old Aug 13, 2005 | 11:14 PM
Default now a/c question
Do you have the 4th Gebn a/c components in your trans am? under dash ones? fit perfectly or needed to mod some things? I was able to intstall my radiaot standing straight up with a shroud off a 1997 camaro. Now messing with the a/c
