Trailblazer conversion
Old Aug 16, 2005 | 06:41 PM
donpenn's Avatar
Default Trailblazer conversion
If this has been beat to death please point me to the info.
I have a chance to buy a loaded 03 with a damaged motor how easy would a ls1 swap be and retain all functions. is it do a doable swap since gm offers it in the ext version. thanks for any guidance ,don
Old Aug 16, 2005 | 07:37 PM
spy2520's Avatar
If they can fit a ls2 in a trailblazer SS, an ls1 cant be too hard. No info though.
Old Aug 17, 2005 | 09:48 AM
randyc's Avatar
The Trailblazer/Envoy were available with 5.3 aluminum V8s so all the parts will be available, mounts, rads, hoses etc. The intake is different from the LS1 (truck vs F body) but could still be used. The throttle body was electronic not cable and the fuel lines had a return line. The accesory drive is the same as the trucks. The exhaust manifolds are unique. Should be an easy swap.
Old Aug 17, 2005 | 09:53 AM
digitalsolo's Avatar
Should be pretty straight forward. A 97 Vette fuel rail should mate right up to the Trailblazer fuel system, and I'm sure an F-Body throttle cable will snap in pretty directly.
Old Aug 17, 2005 | 04:34 PM
randyc's Avatar
I just remembered another unique difference. THe oil pan is completely different. It has a front sump and a hole for the front drive shaft to run through. They should be available from an auto wrecker. I know of one here in Canada.
Old Aug 17, 2005 | 09:37 PM
LS1NOVA's Avatar
Your definately better off finding a 5.3 out of a trailblazer with all the stuff you need to swap. I cant imagine how much all of that stuff would cost from GM. Also the various modules in the Trailblazer seem to be more sensitive on Class 2 comunication. Definately would advise to use a factory harness and just plug everything in.
Old Aug 19, 2005 | 10:25 AM
Oscar Will's Avatar
Just fix it and trade it in. The new Trailblazer SS has a 6.0l in it and all you need to do is make the payments. I guess I'm getting cynical and lazy in my old age! Ha!
