6.0 Id
Old Aug 20, 2005 | 02:24 PM
super nova's Avatar
Default 6.0 Id
I found what looks to be achevy 6.0 in a local salvage yard, but I dont know to tell just by looking at it. the only markings I found 5.3 on the back side of the passenger side head, what does this mean. Also can anyone tell me how do identify 6.0 just from lookin
Thanks
Old Aug 20, 2005 | 07:23 PM
FastKat's Avatar
Probably a pretty crude way to identify a 6.0L engine is that the heads will have "317" stamped into the corner. It sounds like you have found a 5.3L engine, which is also pretty decent!
Thanks
Old Aug 21, 2005 | 09:48 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
If you can see the front or back of the block, you can tell whether it's a 4.8/5.3 or a 6.0 by looking at the casting. Since the 4.8 and 5.3 share the same block, it's a little tougher to tell those apart (actually alot tougher).
You have to be able to see either behind the water pump/accessories on the front, or behind the flywheel on the back. The head casting numbers are also a good way as long as they haven't been changed.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
