12 volt disconnected and computer program lost??
The question is how long will the computer keep its custom program when 12volts is disconnected. I had mine disconnected for about 2 weeks. When I reconnected it all it will do is run for about 5 to 8 seconds then die, and when I try and restart it just hits once and dies. After the first 5 second run the check engine light does not light up.
To fix this I need LS1 edit?
I went on vacation and thought that someone might want to steel my LS1CJ5 so I hid the ground wire. A friend up the street had a car stolen and I was being mybe a bit too cautious.
Thanks
LM
A re do, cause 12 volts is more specific than power
