My LS1/T56 swap into '68 Chevy C-10 stepside
Old 08-05-2008, 11:39 AM
  #221
shifty`'s Avatar
lol
i wish i had some. one of you guys want to swing by my house this weekend and help me finish my frame so i can send it off for powdercoat? or you just want to sit here and harass me?
Old 08-28-2008, 01:16 AM
  #222
Ford_Assassin's Avatar
I was looking at your pics gallery, where did you buy your intake? I want to keep my battery in the factory spot, which means running the intake there isn't happening.
Thanks!!
Old 10-07-2008, 12:54 AM
  #223
Digging up an old thread....
I have '98 F-Body manifolds for my 5.3 swap that is nearly finished. I was wondering where you guys bought the exhaust flange that bolts to each manifold and connects with the rest to the exhaust? I plan on fabbing my own exhaust in my garage and these are the only pieces I am having trouble locating.
Thanks!
Old 10-08-2008, 08:58 PM
  #224
shifty`'s Avatar
I got my intake off eBay, it was a tube for a newer model with a cone filter, but i relocated the battery
As for exhaust flanges, I bought 2.5" or 3" downpipes pre-welded here on the forum. Not sure where to buy them.
Old 10-10-2008, 08:11 AM
  #225
Originally Posted by shifty`
......but i relocated the battery
How/where did you move the battery?
Thanks!!
Old 10-10-2008, 09:48 AM
  #226
350SS's Avatar
Thanks!
stainlessworks but be preparted to pay
Old 10-19-2008, 10:32 PM
  #227
shifty`'s Avatar
Thanks!!
passenger side, using the auxillary battery tray from a 71-72 camper or something. left a link for the shop i bought it at on the truck forum, may be info about it in this thread, can't recall.
Old 10-24-2008, 10:00 AM
  #228
A_VAS's Avatar
Anybody know if you can buy just the "block" part of the ECE mounts? I have stands and old style mounts I can use, just need the part that connects to the engine block and straddles the mount. Hate to spend $219 just for those 2 pcs.
thanks
Old 10-25-2008, 11:13 AM
  #229
I bought Brother's tubular frame stands ($120) and Trans-Adapt LSx engine adapter plates that included motor mounts for ($50). Plus, I could of used the the Trans-Adapt adapter plates with my old frame stands if I wanted. I just figured I was better off with the extra room.
Old 10-26-2008, 07:34 AM
  #230
saad94's Avatar
One of the best project. great work u done.
Old 10-27-2008, 11:47 AM
  #231
A_VAS's Avatar
by "extra room"....you mean the tubular stands tuck in tighter to the frame?
thanks for the info
Old 05-03-2009, 01:37 AM
  #232
thanks for the info
No, they are aren't near as wide as the stock sheet metal frame stands so it lets you get around the stands easier.
Hard to explain, check out my swap thread, there are pics.
https://ls1tech.com/forums/general-l...9-c10-swb.html
Old 07-27-2009, 10:22 PM
  #233
Patches's Avatar
Default headers
I have a 69 c-10 i just put a ls 6.0 out of a 2004 2500 hd truck in it. Using trans adapt motor mounts and a tci flex plate to go to the old school 400 turbo, and ordered my wiring harness from Howell EFI performance. Everything is pretty much going fine with the swap except my exhaust. I am having trouble finding exhaust headers to fit. My stock maifolds want even fit (driver side does, passenger side does not). Does any one have any sugestions. I would really apperciate it.
Old 07-27-2009, 11:44 PM
  #234
I have set of modified Hedman Torque-Step '98-'02 F-Body long tube headers that I used with my '69 C10 SWB LSx swap that I don't need anymore due to parting out the truck and using the motor/trans in my Datsun.
They are ready to bolt on, $200+ shipping.
Just let me know.
Old 07-28-2009, 10:17 AM
  #235
Terry'sToy's Avatar
I used a set of early LS1 manifolds on one truck, and I modified a set of headers from the 98-02 trans-am for the other truck. The header mod is a pain.
Old 07-28-2009, 10:47 PM
  #236
Patches's Avatar
I appreciate the info. Let me make a few calls tommorro and i will get back with u on those headers. I live in kentucky so that shipping is probably going to be high. I have a mismatched set of f-body headers now i got off my buddy but there going to require a little rework to get to fit. I have even thought about flipping the manifolds upside down and going with a turbo set up.
Old 07-18-2010, 07:51 PM
  #237
newby96's Avatar
nice build. Im doing the same thing. I got a 68 swb and im putting in a turboed 5.3. ill try to load up some pics if i can. but i gotta ask you guys something. I'm having a problem with it starting. I got power to everything got 60 psi fuel pressure. the problem im having is as i go to start it the truck will fire up for like 2 seconds then dies. what i'm getting is the injectors arent getting any power from what i can see from the noid lights they loss power after it starts up. any help would be greatly appreciated.
Old 07-18-2010, 07:53 PM
  #238
blownerator
BlownChevy's Avatar
VATS (vehicle anti theft system). Have a tuner turn it off for you.
Old 11-21-2010, 09:39 PM
  #239
kaotic_ws6's Avatar
i wasnt sure where to post this and i thought this would be a good spot, im doing a ls1/th400 in a 67 swb chevy, and i need a proportioning valve for full drum brakes no power. i cant find one anywhere please help!
Old 12-05-2010, 06:42 PM
  #240
shifty`'s Avatar
I would check the www.67-72chevytrucks.com forum, honestly. Those guys are totally nutso about these trucks and can give you the answers you need.
Meanwhile, this truck is torn down to the frame and has been for a year-plus, hoping to get back on it in 2011.
I don't regularly check the forums, so if you're thinking about PM'ing me about stuff... I probably won't answer in a timely fashion.
Quick Reply: My LS1/T56 swap into '68 Chevy C-10 stepside
