using a return line
You can use the 97-98 Vette fuel rail (regulator in the rail).
You can use the 99 and up Vette filter/regulator assembly and mount it wherever you want.
You can use an aftermarket adjustable fuel pressure regulator and mount it wherever you want.
Each of these methods allows you to "create" a return line so that you can maintain the needed 58 psi and send the excess back to the fuel tank.
With any of these methods you can hook up with aftermarket fittings and use braided line if desired.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Regards, John McGraw
Others have use the dual line setup but with that setup you have to run two lines fuel feed and return from the fuel rail plus install a fuel pressure regulator.
Both ways are correct. Just decide which one is correct for your application.
In my situation I mounted the FFR near the tank and ran the return line directly back to the tank with a short line. I am using the stock fuel vent line and the stock single fuel line to the fuel rail. I then only had to route a flex line with the proper quick disconnect to the fuel rail. I did add a extension hard line to a custom location before I changed to the flex line.
I hope this helps. John Bzdel did the duel fuel line setup on his motor, you can read how he did his swap on his website. He has links all over this forum to his website.
does that sound correct?
Here's what it looks like:
www.speartech.com
www.speartech.com
I'm going to be using a LS2 with the LS2 intake and 05 fuel rail/injectors. Is this a return less style setup? If so, will that corvette unit be the easiest to use? At what point does that setup become too restrictive?
Thanks
Nick
Thanks
Nick
www.speartech.com
Thanks
Nick
Yes, the LS2 is very similar to the LS1 fuel rail; just a single feed line, so the Vette filter/regulator is a good way to go. Or you can go with an aftermarket adjustable regulator which just comes with threaded holes so you can plumb it up any way you like.
The Vette filter/regulator isn't necessarily the easiest to use, but it is by far the cheapest.
It will support quite a bit of power since it comes stock on the Z06 and guys are modifying those to some pretty decent drag times.
www.speartech.com
Thanks
Nick
We have the Vette filter/regulator for $50 which includes the male adapter tube as pictured above.
www.speartech.com
