Electric throttle body conversion.
Old Aug 27, 2005 | 11:33 AM
70 LS1's Avatar
Conversion master
Default Electric throttle body conversion.
I am interested in adding the C5 electric throttle body to my car. If I get the pedal, throttle body and TAC module, what else do I need? Is there any interaction (other than traction control) between the TAC and anything else or is it pretty much a stand alone system?
thanks
Old Aug 28, 2005 | 07:59 PM
John B's Avatar
Moderator
I am considering this too since the LS7 is set up this way. According to Speartech you also will need a C5 PCM which seems like a real bummer
Old Aug 28, 2005 | 08:14 PM
CamaroCain's Avatar
What about using a truck/avalanche/tahoe/suburban pcm?? they also use electronic TB's??
Old Aug 28, 2005 | 08:26 PM
70 LS1's Avatar
Conversion master
John, you can still use your F-body PCM. I talked to John at Speartech and he said you just need to have it flashed to a Corvette. The basic pinouts are the same and you won't have to change your harness other than adding the two wires for the TAC.
Old Aug 29, 2005 | 06:53 PM
John B's Avatar
Moderator
Now I remember the discussion! I was bummed because I would have to buy another LS1_Edit license to do this
Old Aug 29, 2005 | 07:40 PM
Scooter70's Avatar
LS1Edit? Come on John... At least upgrade to HPTuners or EFILive!
I don't know about the Corvette guys but the '05 GTO guys are having issues with the pot in the pedals failing. I think it's a different setup from the Corvette/truck but it's something to look into. So far I haven't had any problems with my Goat. (Knock on wood.)
-Matt
Old Aug 29, 2005 | 10:57 PM
John B's Avatar
Moderator
That's part of the problem Matt.....even if I upgrade then I still need to buy another package since I'm sure that the math based LS7 PCM will require a different set-up entirely and I'm not up to spending upwards of $1500 on just software beteween my LS1_Edit, upgrading to HPT and then buying another HPT or whatever to do the LS7 PCM when it comes out!
Old Sep 3, 2005 | 11:01 PM
rickbat's Avatar
I sold my LS1 edit on eBay, I hated it!!!
Worth spending the $500 on HP Tuners they claim the 2.0 release will support the LS7 if purchased now it would only be a $100 upgrade to add the LS7 PCM later.
