where to run autometer water temp sender??
Didnt realize the other head had a plug....thank you
(BTW, the left and right heads are the exact same casting. It doesn't matter which one you put on either side, except that the wiring for the stock water temp sensor is on the driver's side.)
Two relays set for 180 and 200 worked well for me.. the PCM (ECM) sometimes fights with trying to turn them on/off.
Mount the sender to the hole in the side of the passengers side head. You will need an adapter due to the threads.
It is just that easy
http://www.circuitflex.com/WaterTemp.jpg
-Matt
You are better off running independant fan relays.. I ran two with two seperate sensor bungs in the radiator..
You can see the relays and sensors in this pic.. the sensors at the two items right below the trans line and the relays are the two black boxes to the left of the pic.
It does need to know the air temp (IAT).. but could care less about water temp..
You can see it in this picture just behind the header flange.. with the temp sensor installed.
