plug wires with sw headers
Old Aug 31, 2005 | 03:31 PM
69blackwidow's Avatar
Default plug wires with sw headers
need some help , what plug wires do you guys have. my stock wires on the driver side are right up against the header pipes but all ok on pass side. do they make a set with angle boots mike
Old Aug 31, 2005 | 10:13 PM
69cam's Avatar
Default MSD Super conductors.
I ran into the Same Problem with my headers. I ended up buying A set of MSD Super Condoctors that have the plug boot that is flexible so if you need it angled or straight you can bend them as you wish basically.
Old Sep 4, 2005 | 05:11 PM
Wing Zero's Avatar
MSD wire are the only one I have found to work with all headers that have this problem
Old Sep 4, 2005 | 08:06 PM
glennhl's Avatar
I had the same problem. First I wrapped the one that was laying against the header pipe with thermal tape. Lasted about 9 months and started missing. I went with the MSD's also. They worked great. I bought a fire sleeve for the one that was against the header, but it was a waste of money because like the other people said, you can bend the plug boot to any angle you want. Works great!
