lt1 alternator wiring help
you will need to get a connector for the alt, as one of the wires needs to be connected to 12v+ to turn the voltage regulator on. this function is needed for charging to take place.
im unsure the exact wire. i think the brown wire.
dont blow anything up.
you can convert it to a regular 1 wire at a starter and alternator service shop.
good luck.
www.camaroz28.com might be a better site for your lt1 needs.
