burned out my fuel pump?
Semper Fi,
Clay
Semper Fi,
Clay
Check the simple stuff first like the fuse. Then check the wiring to the pump making sure there is power and a ground. Clean the ground. Use a test light to check power because a broken wire can have voltage pressent but not connect enough to allow current to a load. If you have to drop the tank and pull the pump power it up directly and see if it works, it just might be just the wiring connection.
The last item is it just went bad, stuff happens.
I hope this helps
inline pumps suck.. lol.
seriously though, take it out, backflush it, and see if you can get it to work on the bench...
He admitted that it wasn't a truly accurate test, given that in real-world conditions the engine would have shutoff and the pump circuit would have opened rather than allowing the pump to continue running dry, but they did conclude that the plastic impeller would have incurred damage to some extent in the few seconds of dry running. (they requested funding to repeat the FMEA test in real-world conditions but got shot down)
heh, i can double confirm that..
almost everyone ive seen fail has had the impeller melted...
if you take it apart and get it "fixed" you can make a intresting backpack squirtgun.... lol. deadhead it to a blowgun.. with the melted and now slightly smaller impeller, they work fine without a regulator.
I hope this helps
How much current does it take to light a test light? If you really want to check the wiring, Take a old sealed beam headlight and use it for your testlight, atleast you are drawing a few amps. Thats what our shop has done for years.
