gto ls1 in 71 camaro
To answer you question, I think it would be easier to go with the f-body engine. They are easy to find at a reasonable price, they need little modification to fit into the 2nd gen bay and there is a few people who have done this so there is info out there. As for the drive by wire throttle on the 05+ GTO, that would just be extra pain to adapt into your setup...unless you are up for the challenge.
Are you a member of www.nastyz28.com ?
The fuel system you are planning to use is different from mine so I don't know much about it. However, check this link. http://matt.undiagnosed.org/ls1/fuel.html He has the kind of set up you want. You should be able to use the 3/8 supply line but I would not recommend using the eec line for a return. You might want more info on that from others.
As for the clutch, go to street and performance and get their clutch master cylinder support bracket. http://hotrodlane.cc/PROJECTS/projectsindex.html#ls Follow this link and see how they use the braket. Check out the Biscayne, camaro and chevelle projects.
What else do i have planned? Lots. I have been researching this swap for almost a year now and have taken lots of note and saved lots of web articles that help me. I will upgrade the wiring to handle the increased voltage demand and make the LS1 feel at home. As for the wiring harness and computer , I will leave that to the pros...i don't care to delve into adapting the harness for my setup.
Right now my car is running a small block 350 and 350 trans. They will be up for sale soon. here is a pic of my car. http://community.webshots.com/user/bobkiny
How about you...have you started the project yet? I am sure I can try help if you have any other specific questions.
