Charging/Decharging question
Old Sep 7, 2005 | 09:04 AM
Unstang's Avatar
Default Charging/Decharging question
Where do I start looking for the reason my battery was drained this morning? I tested the battery, it tests good. No previous problems. It is a 5.3 in a '94 Toyota truck. Any help is greatly appreciated!
Old Sep 7, 2005 | 09:42 AM
rnp.ent's Avatar
remove neg batt cable put test lite between cable & batt if the lite is on you have a current draw..
disconect anything that has a normal draw, dome lite ect (if door open ect)..
start pulling fuses till the lite goes out then trace that circut..
this method has always worked for me.. good luck
Old Sep 7, 2005 | 09:56 AM
Unstang's Avatar
Thanks, I will give that a shot tonight after work.
