'67 camaro oil pan, headers...
Old Sep 8, 2005 | 09:52 PM
67RSCamaroVette's Avatar
Default '67 camaro oil pan, headers...
I'm kinda frustrated. Normal long tube headers for my '67 with a small block chevy cost $350-400 for a set of coated with 1 3/4" primaries, 3" collectors, right? 200 or so for uncoated. S&P's and Stainless works headers all cost to the north of 700.. I sure aint payin that much for headers. Dynatech sells the LS1 header flange for like 50 bucks. Grinding the normal flanges off a set of uncoated hooker super comps, maybe tig welding them to the dynatech flanges, and having them coated would cost less, as well as allow me to run an exhaust made for the '67... I dont know. I really don't want to do that. There's gotta be a good solution to this. The prices for conversion longtubes are ridiculous. Anyone help? Also, will the GTO oil pan (front sump) work on my camaro without notching? Anyone know how much John's pans cost? John?
/sigh.....
olly
Old Sep 8, 2005 | 10:42 PM
Slayn's Avatar
Corvette exhaust manifolds?
Old Sep 8, 2005 | 11:37 PM
Already on the motor . (99 vette powerplant) That'd prob be the cheapest and easiest solution, huh. I'm not going real big with the engine anyways. (slightly agressive cam, maybe heads down the road..) Coated headers look so pretty though. Gonna go with a 2 1/2 or 3 inch down from there, to cutouts, then X pipe, then dual mufflers and dumps. Unless there's a good long tube header solution.. anyone?
Old Sep 9, 2005 | 08:38 AM
mjls1's Avatar
Active Streak: 30 Days
Just seen some headers on ebay, item #7998139888. Don't know if they would work or not. Looks like they need work yet, but they are at about $100. Thought i would let you know.
Old Sep 9, 2005 | 10:08 AM
1fastWS6's Avatar
I think BBC headers could easily have the flange cut off and the LS1 flanges welded on since the tube spacing is similar. you'll still have closer to $600-700 in them though unless you can weld/modify them yourself. how about a mid-length LS1 header? those might fit.......
Old Sep 9, 2005 | 10:28 AM
79ls1's Avatar
I dont know about clearance but pace setters fit my project and they were 400 coated w/ gaskets
Old Sep 9, 2005 | 07:49 PM
Yeah i saw those on ebay. I'd rather do my own. They were MIG welded, so there's probably tons of little bits of wires and spatter inside those bends. TIG is the only way to go for flow. There's gotta be a solution....
Old Sep 9, 2005 | 08:10 PM
SatisTraction's Avatar
this is what i did. it fits great now!! and it only cost about $300
https://ls1tech.com/forums/conversions-swaps/329889-ls1-pace-setter-header-67-pics.html
Old Sep 9, 2005 | 08:59 PM
You posted the hyperlink to the same forum =). Any chance of getting the link you were trying to send?
Old Sep 9, 2005 | 11:06 PM
Nevermind. I did a search on your posts, and found your setup. SWEET. That's what i'm doing. Hope you dont have a patent yet.
olly
Old Sep 11, 2005 | 07:19 AM
sorry about that
try this
https://ls1tech.com/forums/showthread.php?t=329889
Old Sep 12, 2005 | 11:56 AM
Steve68's Avatar
Satistraction, Why did you modify the headers? was the tube touching something or was it too low, I like the Stainless works headers bit if I can save a little, The guy above says he used Pacesetter LT in his 79 which is front steer, they probably wouldn't work in a rear steer, Thanks Steve
Old Sep 12, 2005 | 01:58 PM
mine is rear steer. the front tube was hitting the PS box and the 2nd tube was about 1/8" from hitting it.
Old Oct 3, 2005 | 10:32 PM
sick six's Avatar
im doing a 1st gen ls1 conversion & manifolds off a 2000 vette didnt work on driver side.
Old Oct 3, 2005 | 10:46 PM
You're correct. Mine wouldnt fit either. The collector hit the p/s box, and my master cylinder for my clutch was really close to it, too. Ordered my Pacesetter offroad LT's tonight from summit =)
olly
