LQ9/LS1 questions-
If so, is there any major issues aside from just one different sensor/plug and some wiring extensions?
It just seems that with nitrous and all, I can likely pull more power, more safely from the LQ9, and the price is quite.. excellent.
Then I'll have a 98 LS1 longblock to put in something else. Fiero maybe.
both motors pistons and rod bolts will fail under hard nitrous use.
you are better off spending money on forged pistons and rod bolts, IMO.
the aluminum block can be a weak link in the high horsepower range, but by then, most have upgraded to good internal hard parts.
i doubt it will make anymore power than what you have, and you will be carrying an extra 100 pounds to slow you down.
good luck.
good luck.
good head studs, and you can get away with a lot more power in the aluminum block.
you are a good 400 pounds lighter than most f bodys, and 1000 to those in street trim.
dont sound like to bad of a swap, but i wouldnt waste time putting it in stock.
build that bad boy then throw her in.
sounds like a fun project.
9's and toy-bo!
sweet.
