question about mafs....
Old Sep 17, 2005 | 06:16 PM
slowassta's Avatar
Default question about mafs....
im swaping an LS1 into a LT1 car. My ? is do i have to get an LS1 maf or can i still use my LT1 maf... thanks
Old Sep 17, 2005 | 07:56 PM
NX74LS6's Avatar
I used my LT1 GMMAF in my 01 SS after dropping a whopping $60.00 for an LS1 program. That's it. You're ready to go.
Old Sep 17, 2005 | 08:06 PM
TAQuickness's Avatar
you could always !MAF unless you have a specific reason you need a MAF.
Old Sep 18, 2005 | 01:28 PM
slowassta's Avatar
thanks for the info guys
Old Sep 18, 2005 | 04:22 PM
yodawagon's Avatar
can you run a 02 ls1 without a maf?
Old Sep 20, 2005 | 12:35 AM
yodawagon's Avatar
ttt please
Old Sep 27, 2005 | 06:45 PM
67RSCamaroVette's Avatar
How do you run it without a MAF? I don't have one on my engine, and if i can run it without, that'd be awesome. Is that what "closed loop" means?
olly
Old Sep 27, 2005 | 10:15 PM
AnotherScreenName's Avatar
olly
Closed loop is the one that requires a MAF. Closed loop refers to a feedback/adjustment cycle between the MAF monitoring incoming air and the oxygen sensors monitoring air/fuel ratio in the exhaust and the computer adjusting fuel accordingly.
Without a maf your in open loop and the computer refers to tables to adjust fueling, its commonly referred to as speed density mode. You would need some tuning software to adjust the tables that the computer refers to to match your setup then you can go mafless.
Old Sep 27, 2005 | 10:26 PM
slow's Avatar
not totall correct on the open closed loop.
MAF and open closed loop have nothing to do with eachother.
Open loop, meaning the computer is only relying on inputs for airflow, through maf and SD calculations to determine the airflow, and providing the correct fueling, without feedback from to o2's to determine if the fueling is correct.
Closed loop, the computer uses the o2 sensors to provide feedback to alter fueling to reach the stoich point of the fuel, with gasoline, 14.6x is the typical airfuel ratio you achieve.
MAF, meaning the computer uses both the maf and the VE tables/map sensor to do the dynamic airflow calculations
SD, the comptuer is only using the VE tables, and map sensor to calculate airflow, to then caluclate fueling.
You can run in any of the following situations:
MAF, Open loop
MAF, Closed Loop
SD, Open loop
SD, Closed Loop.
Ryan
