Modify a 94 Z28 fuel system for LS2
Old Sep 25, 2005 | 10:30 PM
gogogadget's Avatar
Default Modify a 94 Z28 fuel system for LS2
From what I have read it appears that I can use a vette fuel filter/regulator and run the return line from the filter back to the tank. That will allow me to use the stock ls2 fuel rail assembly.
Is this as simple as cutting the excess return line running to the engine compartment and hooking the remainder up to the filter/regulator unit? (which I would probably mount in the stock filter location in front of the rear drivers-side wheel)
