LT1 swap into a malibu
bought a cross member from crossmembers.com and new motor mounts in the correct holes and it drops right in. the trans linkage bolted up even, you need to get an AC delete pulley, or notch the frame on the passanger side. we rigged in an LT1 radiator and fans even. biggest problem we are having is with the computer and wiring. for all the trouble that it is i wish we would have put the LS1 in instead... btw if you want to buy the stuff for an LT1 swap talk to me, i want to get rid of it so i can get an LS1 (LT1 in the wagon does not run due to electrical/computer/spark issues)
