gas tank question
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
And here is a link to an actual install.
http://www.thedetailzone.com/Tanks%2...%20Install.htm
I am using one of their tanks and pumps in my swap, just ordered them. Once I get to that point I will post how they worked.
Pat
Aluminum or plastic, but many of the car specific swap tanks are megabucks.
NM just saw the above link, seems like a good plan if you can go that route and install the pump/pickup in your stock tank.
Not sure about the camaro trunk, but in my foxbody mustang a rci 12gallon fit great in the spare tire well without having to cut anything up(except for the hole for the sump)
You should be able to fit a 16gallon no problem if the floor is flat, and you dont need the truck room...
Regards, John McGraw
I mean soda.
