TOYOTA SWAP, Bolt patterns?
Old Oct 2, 2005 | 09:10 PM
zapp168's Avatar
Default TOYOTA SWAP, Bolt patterns?
700R4 will bolt to a LS1 correct? and what is the difference where an old 350 motor mounts are and a LS1?
I have an 89 Toyota pickup with a 1976 350 and a 700R4 that I already put in to it. Looking to upgrade, and is 40 lbs.enough fuel preasure?
Old Oct 2, 2005 | 09:18 PM
01PewterWS6's Avatar
Ls1s need 58psi....
Use adapter plates for the motor mounts you have, to use 3bolt chevy motor mounts....
I would try to find a 4l60E to mate to the ls1 before Id try to make the 700r4 work.
Project GatTagO's Avatar
If your truck is already set up with mounts for the 350, then you should be able to get adapter plates from
http://www.hotrodlane.cc
Your fuel pressure needs to be at 58psi. That is the stock LSx pressure.
Andrew
