Fuel System
Old Oct 6, 2005 | 09:50 PM
72short_cut's Avatar
Default Fuel System
im putting a 99 ls1, into a 72 Chevy Short box. im starting the fuel sytem, ive got the holly 12-920 external fuel pump, and running the Gm corvette fuel filter regulator part# 10299146. which will be mounted in the frame rail, coming from a rear mounted fuel tank with a top supply feed line. im also going to mount a pre filter before the fuel pump recommend by holly. i was wondering if there was any concerness or issues with the set up im going with.
thanx
Old Oct 7, 2005 | 10:51 PM
WILWAXU's Avatar
Lets try this in our Hybrid section.
Old Oct 8, 2005 | 12:34 AM
jdperk-86elco's Avatar
thanx
It should work but it isn't the best setup. You will need a feed line to the pump, return line from the Corvette Fuel Filter Regulator (FFR) to the tank, and the tank vented. The vent can come from a charcol cannister. Of course your external pump will work and a filter between the tank and the pump is a good idea for an external pump but again it isn't the best setup.
The better setup would be to put in a tank setup for Fuel Injection (FI) with an internal pump. The pump will feed the Corvette FFR which its return line back to the tank, and the tank vented and your done. The last thing is from the outlet of the FFR to the fuel rail. The FFR regulates the pressure to 58psi the LS1 requires.
Again your setup should work if the pump will put out the pressure and volume but the intank pump will run cooler being in the fuel.
I hope this helps.
Old Oct 9, 2005 | 02:02 AM
what would be a good in tank fuel pump to run instead of the external i was going to run.
Old Oct 9, 2005 | 12:53 PM
Walbro is a good one. Get your tank and then get a fuel pump to match it.
