Progress on my S-truck swap
Next are the headers. 1 3/4" longtubes, 3" collectors, entirely of 304L stainless. I'm no stranger to fabrication, but this was a challenge. Starting with a big box of bends, a pair of flanges, and two collectors from Stainlessworks (>-----sponsor), I cut, fit, tacked, and finally welded out a set of headers that clear everything, (even the upper A-arms at full suspension compression) and should help me get the most from the heads/cam swap that is planned. Now it's on to the rest of the exhaust system.
More updates as they happen.......
David
Your truck looks good. Did you think before you started it would be as much work as it has turned into? Years ago, when I put the L98 TPI in my truck, it wasn't half as hard as this LS1 is turning out to be. Even though, I think it will be worth it when it is done.
Yeah, but even if I could get $400 each for them, (fat chance!) I'd still lose my a$$ because of all the time I have in them!
Does Lees High Tech have a website... or contact info? Please PM me.
Wondering if the pictured A/C bracket would fit in an 03 S10? I'd buy one
Does Stainless Works make a set of headers that will fit in the last model S10's? I haven't talked with Al in awhile... maybe I should give him a call. BTW, nice headers
Bill
No, it was just easier while I was fabbing up the headers to raise the cab up off the frame with the lift after checking fit. The LS1 swap isn't all I'm doing with the truck. Many other mods, plus bodywork, paint, interior, yada, yada, yada. Maybe one day I'll have it back together......
It isn't really hard to swap into an S-truck, but it is a lot of work to do it right. Anyone with decent mechanical skills and lots (lots!) of patience can do it. Oh, yeah, don't forget to bring a bunch of money!
With a stock LS1, quarter mile times will be roughly similar to a stock LS1
F-body. The S-truck isn't as light as most people think, unless you have a 2wd regular cab short bed with no options. My 2wd extended cab with most power options was over 3400lbs.
Also, I would like to comment on Lee's High Tech. The guy does great work, but he doesn't get things to people in the most timely manner alot of times. Now, his stuff is expensive but you do get what you pay for also. He may not even have a set of LS1 headers out yet. I know they were talking about it but who knows if anything ever came of it.
are you building it for just something nice or bagging it or are you coilover/4 link/hot rod style? I'm doing mine for 1 season of racing in the Super Stock class in the EFI nats, then its to do it the way i want.. shockwaves all around, 4 linked, etc..
nice work so far, it looks reallllllly good.
you're looking at ~3500 if you have the 700r4 and want a stock swap... even more if not... i'm building mine piece by piece.. gonna cost more, but its what i can afford right now. (dont forget motor mounts and the nickle and dime ****)
