putting a t-56 in '92 fox body
Old Oct 13, 2005 | 07:19 AM
1dirtyZ's Avatar
Default putting a t-56 in '92 fox body
i'm thinking of putting an ls1 in a foxbody mustang i have, the thing is i already have a t-56 sitting in my garage and want to use that too.
what would be the easiest way to put that tranny in?
should i get a bellhousing, clutch , and throw out bearing of an lt1 setup and try to make it work with the clutch cable on the mustang? or should i just convert the whole clutch linkage into a hydraulic setup and reuse the clutch, bellhousing, and throwout bearing i already have??
or should i just stick to the t-5 ( or tko ) thats already on the car?
any input would be greatly appreciated!
Old Oct 13, 2005 | 08:10 AM
Brains's Avatar
A cable clutch setup would be the easiest, since there's not much room on the flimsy firewall of a Mustang to mount a clutch master cylinder. If you convert to manual brakes or possibly the Hydra-boost brake system, you could probably fit the master.
Old Oct 15, 2005 | 05:20 AM
1dirtyZ's Avatar
cool, do you have any sites that have anything related to a swap like this?
now if iuse an lt1 setup , what flywheel do i use and what clutch do i use?
can i go with an ls1 flywheel , ls1 clutch , and an lt1 throw out bearing and fork assembly? will i have to buy an lt1 bellhousing?
Old Oct 15, 2005 | 09:40 AM
93Polo's Avatar
As far as I know it has not been done yet. for some more info:
https://ls1tech.com/forums/conversions-swaps/286585-new-discoveries-ls1-into-mustangs-swaps.html
Old Oct 16, 2005 | 08:16 AM
1dirtyZ's Avatar
i found that thread after i posted , it should be a sticky
lots of good info there.
