Is there a solid answer on TB bypass methods?
Old Oct 18, 2005 | 08:30 AM
MrDude_1's Avatar
Originally Posted by ls1_chevelle
You confused me with saying no.
it must goto someplace in the system WITHOUT pressure.
in response to "I'm pretty sure it must go on the pressure side of the radiator(the overflow tank is on the non pressure side). Someone makes T's that go in the high side radiator hose for this return......."
-Matt
you missed one small part.
hes calling the entire cooling system pressurized.. and it is compared to the atmosphere... hes saying the coolant air bleed line must lead into the system, and that is correct.
im saying WITHIN the cooling system, you have areas with more pressure then other areas. for example, the suction side of the pump has less pressure then the pressure side.
if you lead the line to a higher pressure part of the system, the line becomes "dead".. no coolant flow, it just sits there.
if you lead it to somewhere where it can go to a lower pressure side, such as the radiator return line, either of the end tanks, ect... then it can flow fluid.
when it has a constant flow of fluid, the air bubbles will move. eventually they get to the radiator end tank, and go out the cap.
is that clearer?
Old Oct 18, 2005 | 03:30 PM
ls1_chevelle's Avatar
Originally Posted by MrDude_1
is that clearer?
Better worded
Essentially we're all agreeing with eachother, yes.
-Matt
Old Nov 6, 2005 | 03:23 PM
Heres an update of what I decided to go with. If this link goes down, the same pic is uploaded in my first post...
-Matt
