5.3 into 96 Blazer
Motor mounts are available from Turbotime. They should also have an oilpan available soon to clear the front diff.
I'm not sure you can safely remove the front axle shafts completely. You may have to dissassemble the axle shaft so that you keep the "stub" on the wheel end....Seems to me I heard it keeps the hub together. May vary depending upon year. You'll need to research that too....
And, lastly, I'm not sure if there are any headers or manifolds that fit without serious modifications. This is one area I'm not sure what I'm going to do....
'JustDreamin'
(soon to be putting a 6.0l into a 1999 Olds Bravada)
One of the syclone sites has this setup, but it still is 4x4.
Now if his truck was a '98 or newer (like my '99 Bravada) he (and I) should be able to make everything work off of the LSx PCM without any difficulties (PCM will talk with the BCM and such without issue since they're using the data link). Again, if I'm wrong here, please enlighten me. I don't want any suprises when I do my swap.
'JustDreamin'
'99 Bravada waiting for a 6.0l
