Pic of custom homeade drieveshaft for C5
[IMG]
[/IMG] [IMG]
[/IMG] Did you make or purchase the ends? They're nice looking pieces, regardless. Just curious if its your machine work.....Looks like it'll stand up to just about anything you want to throw at it.....
This ought to be one fabulous machine once you're done....
'JustDreamin'
It should have been a 20 minute job to shorten and weld and I had to make a whole new one.
The only other option was to have a company make a carbon fiber one for like 1500-2000 Way over my budget
The aluminum shaft is probably heat treated. If you look at most aluminum alloys (wrought or cast) most all of them need a fairly specialized heat treatment process to have any strenght. Take for instance 6061-T6. Great stuff, yield strength is like 40 kpsi (40,000 lbs per sq inch). In non-heat treated form, which is what you'd have if you get a TIG torch (or any welding process for that matter) anywhere near it, the yield strength drops to about 8 kpsi (8,000 lbs per sq inch). That's only an 80% reduction in strength (Yikes). And the process for heat treating aluminum isn't simple or inexpensive, so doing it on a single piece basis is usually pretty pricey. And the ends are likely to be castings anyway, so if we assume they're 356T6 (one of the best casting grades) the yield strength (in heat treated form) is only 30 kpsi.
The Chrome-moly stuff won't suffer the same problems, because its undoubtedly in the annealed condition already, and could easily be heat treated to be significantly stronger. 4130 for example has a 60kpsi yield in annealed (hot rolled) form, 85 kpsi in cold drawn form, and can be heat treated (drawn @ 1000 degrees F) to 133 kpsi yield. I personally would leave it alone, because of the risk of distortion, and wanting to keep the material from being the slightest bit brittle.
So basically, in as welded condition, the chrome-moly is at least twice as strong as a factory shaft in heat treated condition.
Personally, I think his choice of materials is spot on. Yes, it may weigh a bit more. But it won't give up nearly as easily. And if he was really concerned about weight, he would have scallopped the flanges to eliminate a fair bit of metal. But that's also alot of machine work, for not alot of reward. Sure, the reduced weight would be nice, and the higher gee-whiz factor would be great, except that nobody will probably ever see his driveshaft while its in the car.
'JustDreamin'
Keep at it, you'll get 'er done and be driving before you know it.
'JustDreamin'
